Configure an ACE IP DSCP
Configure ACE IP DSCP entries to have the filter look for packets with specific DSCP markings.
  • The ACL exists.
  • The ACE exists.
  1. In the navigation pane, expand Configuration > Security > Data Path.
  2. Select Advanced Filters (ACE/ACLs).
  3. Select the ACL tab.
  4. Select the appropriate ACL.
  5. Select ACE.
  6. Select the appropriate ACE.
  7. Select IP.
  8. Select the DSCP tab.
  9. Select Insert.
  10. Specify the operation type.
  11. In the List box, enter the count for the DSCP values.
  12. Select Insert.
DSCP Field Descriptions
Use the data in the following table to use the DSCP tab.
Name
Description
AclId
Specifies the ACL ID.
AceId
Specifies the ACE ID.
Oper
The eq and mask parameters specify an operator for a field match condition: equal to or mask. The mask operator is an implied eq on the mask bits.
List
Specifies a count for the number of discrete ranges entered for the DSCP values. Entries include 0–256, disable, phbcs0, phbcs1, phbaf11, phbaf12, phbaf13, phbcs2, phbaf21, phbaf22, phbaf23, phbcs3, phbaf31, phbaf32, phbaf33, phbcs4, phbaf41, phbaf42, phbaf43, phbcs5, phbef, phbcs6, and phbcs7.
OperMask
Specifies the mask value.
